Water Cooling Advice - New/First Build
RedXIII
16
Hello, I've nearly finalized my new gaming build and I am fairly comfortable with it; besides the water cooling. I would greatly appreciate it if somebody could look over my build and specifically answer my questions below.
■Are all of the water cooling components compatible?
■Size of the tubing? I imagine that 1/2in ID is fine, but what about the 5/8in OD?
■How much tubing will I need (ft)?
■Type and size of barbs fine?
■How many barbs do I need?
■If I use compression fittings, then horse clamps aren't needed; correct?
■Is a tube cutter worth buying, or is a utility knife good enough?
■Am I missing anything in regards to the water cooling? Even if it is something small and you assume that I just didn't bother mentioning.
CPU: Intel 2600K
Case: HAFX 942
Mobo: Gigabyte UD7
GPU: 560ti SLI
PSU: Coolermaster Silent Pro Gold 1000W SLI (Overkill I know, but I would like plenty of extra room)
RAM: G.SKILL Ripjaws X F3-12800CL8D-8GBXM 8GB 2X4GB DDR3-1600 CL8-8-8-24 1.5V
HDD: Western Digital Caviar Black 640GB SATA3 6GB/S 7200RPM 64MB Cache x2 (RAID 0 for OS and games - unhappy with SSD options)
HDD: Western Digital Caviar Black 1TB SATA3 6GB/S 7200RPM 64MB Cache 3.5IN x2 (Storage)
CPU Waterblock: Swiftech APOGEE XT LGA1366 CPU Water Block G1/4 Chrome HI-FLOW 1/2IN Eurostyle Barb Fittings
http://www.directcanada.com/products/?sku=14480AC5649&vpn=APOGEE%20XT&manufacture=SWIFTECH
Pump: Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
http://www.directcanada.com/products/?sku=14480AC9207&vpn=MCP655&manufacture=SWIFTECH
Rad: Swiftech MCR320 Quiet Power Triple 120MM Water Cooling Radiator Black G1/4 Threaded
http://www.directcanada.com/products/?sku=14480AC5149&vpn=MCR320-QP-K&manufacture=SWIFTECH
Res: Swiftech MCRES-MICRO REV2 Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
http://www.directcanada.com/products/?sku=14480AC6987&vpn=MCRES-Micro%20Rev2&manufacture=SWIFTECH
Tubes: Tygon R-3603 1/2" ID 5/8" OD Chemical Tubing (Quantity???)
http://www.jab-tech.com/Tygon-R-3603-1-2-ID-5-8-OD-Chemical-Tubing-pr-3873.html
Barbs: Dangerden Silver Compression Fitting - 1/2" to 5/8" (Quantity???)
http://www.jab-tech.com/Dangerden-Silver-Compression-Fitting-1-2-to-5-8-pr-4217.html
Coolant: Swiftech Hydrx Water Additive Coolant 2 oz Bottle
http://www.directcanada.com/products/?sku=14480AC2403&vpn=HYDRX2OZ&manufacture=SWIFTECH
Thermal Paste: ARCTIC COOLING MX-2 Thermal Compound
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835186020&Tpk=ARCTIC%20COOLING%20MX-2
Price: $2250~
Thanks!
Other than fans, doesn't look like it.
Ah, fans; I actually forgot about those.
How does these look? The rad says that it is designed for low-medium fans, which I'm guessing is anything below 70~CFM?
Scythe Slip Stream Kaze Jyuni 120MM Fan 1200RPM 68.5CFM 24DBA
http://www.directcanada.com/products/?sku=14110AC7800&vpn=SY1225SL12M&manufacture=SCYTHE
I 'd skip the Hydrx and just use a silver coil.
Agreed. Is there an ideal amount to use? Should 1 8in strip do the trick? Any idea if it is better to just drop it in the reservoir instead the tubing?
Without any additives, will I have to worry about corrosion at all?
Keep in mind that thin wall tubing tends to kink easier.
I think I'll switch to;
PrimoFlex Pro LRT UV Green Tubing - 1/2in. ID X 3/4in. OD
Thanks
A few more questions.
■My radiator says it has 1/4in threaded hubs. Will 1/2in ID and 3/4in OD compression fittings work fine?
■I went with Scythe because DirectCanada only carries decent supply of them. Out of those below, which would you recommend? If you feel strongly against them, what would you recommend getting? (From http://www.jab-tech.com/120mm-Fans-c-81.html or http://www.directcanada.com )
Thermalright Stealth Silent 120MM FDB Case Fan 1600RPM 63.7CFM 28.0DBA
http://www.directcanada.com/products/?sku=14650AC1692&vpn=TR-FDB-12-1600&manufacture=THERMALRIGHT
Scythe S-FLEX SFF21F 120MM Cooling Fan 1600RPM 28.0DBA 63.7CFM FDB
http://www.directcanada.com/products/?sku=14110AC5567&vpn=SFF21F&manufacture=SCYTHE
Scythe Kama Flex PWM 120MM Fluid Dynamic Bearing Cooling Fan 300-1600RPM 27.50DBA 63.4CFM by Sony
http://www.directcanada.com/products/?sku=16950AC2230&vpn=SA1225FDB12H-P&manufacture=Others
YATE LOON 120x120x20mm Case Fan - D12SM-12C Medium Speed
http://www.jab-tech.com/YATE-LOON-120x120x20mm-Case-Fan-D12SM-12C-Medium-Speed-pr-3826.html
■Is a shroud worth getting? Gaskets?
Thermochill PS120.3 Shroud for Triple 120MM Fan
http://www.directcanada.com/products/?sku=23080AC6706&vpn=PS120.3&manufacture=Thermochill
120mm Anti-Vibration Fan Gasket - Black
http://www.jab-tech.com/120mm-Anti-Vibration-Fan-Gasket-Black-pr-3268.html
Thanks!
1- 1/4 is the thread size, 1/2 x 3/4 is the ID and OD of the tubing, will work perfectly
http://www.jab-tech.com/Enzotechnology-Compression-Fitting-1-2-3-4-Silver-pr-4678.html
2- I'd grab the Yates
3- Shroud worth it ? Might be, but only minimal gains
Gaskets ? Mine are still in the box, never tried them ( look down ).
I have my fans in a box that acts as a shroud when I choose to put it on the rad.
Something that hasn't been mentioned, do you intend to internally mount the rad ?
If so , what case ?
HAF X 942
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225&cm_re=haf_x_942-_-11-119-225-_-Product
http://www.directcanada.com/products/?sku=11130AC7104&vpn=RC-942-KKN1&manufacture=COOLERMASTER
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/32554-cooler-master-haf-x-full-tower-case-video-review.html
I haven't decided where I plan to mount it yet; probably on the top, internally. Once it arrives I'll have a better idea.
Here is a list of all of my components.
http://img716.imageshack.us/img716/407/pcbuild.jpg
They do, but it costs $22, rather than the $8 from Jab-Tech.
If you had to choose one from one of the retailers below, what would you choose? If they are all bad, I may go for Petra.
http://www.directcanada.com/category/?minorcatid=1495
Thanks
Latest posts
