Water cooling AIO very tight
Jun 8, 2018
13
Hi guys i have a case that supports AIO coolers but the tubes barely get from the CPU to the radiator.
They are pretty tight and looks like to their limit, heres a pic https://imgur.com/a/olxVzMH (not mine btw)
It's a Thermaltake water 3.0 and the case is Thermaltake core p5.
Would it be a problem? Is it ok? Or should I get another case/find a DIY way to mount the radiator?
Have you tried mounting it yet? If so, check to see if there is any slack in the tubes. If not, try a dry placement and see how much slack there actually is. As long as the tubes aren't totally taut, then you should be fine.
Im getting the AIO in the next days, i'm going to try that out. Thanks dude
No problem, but just be weary that it still may not work
