Case:Three Hundred Two with 2 water ports at the top of case
Mobo: ASUS MAXIMUS VI FORMULA LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX gaming board with double-sided ROG Armor, 23C-degrees cooler CrossChill and 120dB SNR, 600ohm audio
Power: Thermal take tr2 600watt
Ram: Savage Memory Red - 16GB Kit* (2x8GB) - DDR3 2400MHz CL11 Intel XMP DIMM
Cpu:Intel Core i5-4570 Haswell Quad-Core 3.2GHz LGA 1150 84W Desktop Processor Intel HD Graphics BX80646I54570
Graphics card:ASUS DirectCU II R9270X-DC2T-2GD5 Radeon R9 270X 2GB 256-Bit GDDR5 PCI Express 3.0 CrossFireX Support Video Card
My question after listing this build is what would be the best way to go for water cooling and what products should be bought to maximize cooling. Looks are not that important as function. That being said I have a cooling system of 2 140 mm. and two 120mm fans at the moment but i need to cool this with water if im going to overclock it without damaging the system. Any info on this would really really help. Its been about 8 years since ive done any water cooling set ups so i have no clue as to what products are out and wich would be used thanks guys!
