Been doing a lot of reading on water cooling systems and had an idea pop in my head. Seems a water cooling solution with a radiator can only be as cool as room temperature. I Was thinking of designing a reservoir in which a pelt could be installed on the side of it. Hopefully keep the water even colder then room temperature. Would this work and have any of you done it before? Also, is it even worth the effort being the room temperature seems to be good enough?
Thanks
Cash
Thanks
Cash
