I hope I can clarify my problem well, as English is not my primary language.
I have pretty new PC, which I built myself from parts in february. Actually, except for the motherboard, as it was not available in my country, it is "little monster" build by logainofhades (http://www.tomshardware.co.uk/forum/id-3127673/build-000-build.html?_ga=2.169004961.1241082614.1498160654-174916544.1498160654#18311401).
But to the topic. I have water cooling, Cryorig A80. All CPU temperatures were fine until today - around 30 degrees (Celsius) when idle, 50 or less when playing games. Today it became 80 degrees when idle and up to 100 when trying to run pretty much anything. It doesn't go higher, as the CPU slows down after it reaches 100 degrees - but of course it impacts performance, programs and games crash or work very slowly. I opened the case, checked the thermal paste (actually re-applied it, just in case) and screwed the cooler back on firmly. All the fans are running, but I'm not sure about the liquid pump. Can't tell if it's working, as I don't really know if the vibrations I feel when touching it are coming from it, or from other components around. It has been really quiet anyway right from the beginning. I also checked if the radiator or any other part of the cooling is not covered in dirt or dust. So my question is - has my cooling system just died after few months of (not so heavy) usage? Should I try doing anything on my own, or just accept the fact, use warranty and ask for replacement?
