Hi Tom’s Hardware,
I’ve recently been having CPU temperature issues; arising to over 90 degrees on idle without load before the motherboard failsafe kicks in instantly shutting down the computer, usually within less than a minute.
This isn’t an issue with airflow as my system is well cleaned and there isn’t much dust from fans to components. I have came to the conclusion that immunity issue is either thermal paste being worn out and in need of reapplying or that my water cooling system has failed.
Hence, I decided to unscrew the backplate of the water cooling and check the situation; however the primary issue is that I can’t seem to screw back the backplate into the motherboard into the ‘4’ holes that I unscrewed the screws from within the motherboard - It might be because I removed the ‘whole’ backplate with the metal frame and the water cooler attached.
Could anyone suggest how I could reattach the frame back into place?
System specs:
CASE: NZXT Phantom 410 Mid Tower Gaming Case w/ front USB 3.0 [+5] (Black colour)
CASUPGRADE: NONE
CD: 24X Double Layer Dual Format DVD+/-R/+/-RW + CD-R/RW DRIVE. (BLACK Colour)
CPU: AMD FX-8320 3.50 GHz Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology *** Extreme OC ***
CS_FAN: Default Case Fan
FAN: Cooler Master Seidon 120M (AMD) Quiet Liquid Cooling system w/ 120mm Radiator (Cooler Master CPU Water Cooling *** Extreme OC ***)
HDD: 2TB SATA-III 6.0Gb/s 64M Cache 7200rpm Hard Drive (Single Hard Drive)
MEMORY: 8GB (2x4GB) DDR3/1866mhz Dual Channel Memory (HyperX Fury White w/Heat Spreader
MOTHERBOARD: Gigabyte GA-970A-DS3P AMD 970 Chipset, ATX mainboard w/ 4 RAM slots, 7.1 Audio, GbLAN, USB3.0, SATA-III, RAID, 1 Gen PCIe x16, 1 Gen PCIe x4, 3 PCIe x1, & 2 PCI
NETWORK: ONBOARD 10/1000 NETWORK CARD
OS: Windows 10
OVERCLOCK: No Overclocking
POWERSUPPLY: 600 Watts Power Supplies (Cooler Master 600 Watts B600 B2 Gaming Power Supply, 80+)
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: AMD Radeon R9 280X 3GB 16X PCIe Video Card [+57] (Single Card)
System specs:
CASUPGRADE: NONE
OS: Windows 10
