So this is my first time trying anything liquid cooling wise to my rig(s).
My first question would be what water cooling system/HW should I purchase which would be;
A): Be under $120.00.
B): Be silent enough to where I wouldn't hear it over my 4 other system fans(Corsair AF's).
C): Will efficiently cool a mildly overclocked FX-6300 (~4.2 Ghz).
I was looking at the Corsair H100i but i'm sure there are better ones out there for the same pricing.
And now onto my second and last Question(More like a 2 part question.)
Essentially I have heard that one must replace the coolant inside a liquid cooling device once every half year or so depending on how the cooling unit is used and how dusty the environment is.
Is this true? And if so how would one go about cleaning/replacing the coolant in the component in a simple and quick manner?
Sorry for the long questions I just need a relatively "in-depth" answer .(Not really)
