Hi can you tell me if you think this combo would work okay. I would have to mount the radiator on the side fan slot. As the one a the back is only 80mm where the fan can take a 120mm fan
Cooler Master MasterLiquid Lite 120 CPU Liquid Cooler '120mm Radiator, 1x MasterFan Pro 120 AB PWM Fan, White LED' MLW-D12M-A20PW-R1 https://www.amazon.co.uk/dp/B06WRRDS73/ref=cm_sw_r_cp_apa_TlVIBbHM751AY
https://www.ebuyer.com/724862-avp-hyperion-ev33b-black-cube-case-cas-107
Currently running early 60s whilst gaming so would like to get this down a bit currently using stock cooler on ryzen 5 2400. With 2 X 120 fans at the front and 80mm at the back
