Water cooling coolant
kol272
21
So i have a question about coolant. I'm planing on building a computer with blue and red LED fans and violet coolant. The only problem is I cant find that color. So my question is can i mix red and blue coolant so i can get violet or is that not recommended and if that is bad then can you link me a store that sells that color coolant?
I generally don't recommend coolants, either. If anything use colored tubing as mentioned, or if you HAVE to have colored water, use dyes and a growth inhibitor.
It isn't generally recommended to use a colored coolant since it can cause blockage over time due to buildup of particles.
A better option would be to buy violet tubing for your setup. It wont make a difference.
I have no knowledge on the mixing of colors being harmful or not though.
