Hi there,
I have an issue with the h60 stock fans where the fans constantly run at 1500rpm. I'm not sure on how to fix the issue. It is very irritating as the fan is very loud and I can even hear it with headphones on.
My system:
https://gyazo.com/ffcf1033a7226add3d038242e00db2da
Cooler setup:
The radiator fan is in push set up so it is pushing air into the radiator.
The pump in in pwr 1. (3 pin)
The fan is in cpu fan 1. (4 pin)
Speeds:
https://gyazo.com/a8eef786b3f9583e3e50a247e8f2fd01
I've tried various different setups to no success. At this point I'm thinking that I should be looking at a new radiator fan. But I want to see if anyone else has dealt with this problem before or knows of any fixes.
Any help is greatly appreciated.
Thanks!
My system:
Cooler setup:
Speeds:
Thanks!
