Hey guys so I want to get into water cooling because im tired of the noise from fans and such. Plus i am very passionate about Computers and want to learn as much as i can.. And w hen it ocmes to water coolling i know nothing.
I plan on purchasing this kit,RayStorm Twin D5 RX480 V3 WaterCooling Kit from http://www.performance-pcs.com/xspc-raystorm-twin-d5-rx240-v3-watercooling-kit.html#Specifications
I have a white tower i ordered the Phantek Enthoo primoo in white. I'm sure it has enough space for rad/fans, as it is an extremely large case. But i just want your guys opinion on how i should go about this. Will it be hard? I believe myself to be a smart person and quick learner so there isn't anything i cannot work out. But i believe even the smartest people need help. So i want your guys help in helping me set up the purchase. And before you read i am not worried about the cost as I like to buy good quality materials. Computing is my passion and i wish to learn as much as i can. So with that in mind please give me your opinions on my current proposed purchase.
My first question is will this kit work with the new LGA 1151 MOBOs.
Does it matter if i get the D5 Vario pump or the D5 Vario pwm pump
And also I am given a selection to choose fitting size.
7/16" x 5/8"
1/2" x 3/4"
3/8" x 5/8"
Does it matter which i choose. Will the raystorm adjust the tubing for the size i choose, is their a benefit of on over the other?
Then the RAD fans i have a option of 3 with different PWMs. I chose the 2000PWM. I assume the noise is will be a higher.
Since my case is white, I'm planning on doing Running a Clear tubing with Blood red coolant. I think the Red/White contrast of case and piping will look nice. I went with this coolant, PrimoChill ICE Non-Conductive Liquid Cooling Fluid. Does it matter what you use? Please let me know
And then their's the option for sleeves on the wiring. I chose to sleeve all wires for a more clean look but if you guys think their is no point please do express your opinion.
I have also chosen a Radiator Stand, The Bitspower RAD support||. I'm assuming it is used to support the RAD and keep it in a locked position. But like i said I am just assuming so please correct me if i am wrong.
Then there is the Phobya Radiator Shroud 20mm - Plexi that i have chosen. I am guessing it helps prevent gunk and other small particles from entering the loop. But please correct me if i am wrong. And also let me know if it is worth getting.
And finally there was no option for an Additive for the Coolant. Unless the coolant i chose has additives pre-added into the coolant. So please if you have time please read my post and give me some helpful advise and opinions on what to do. It will be of great help to me and I will really appreciate you guys taking time out of your day to help out a fellow brother.
So please let me know what you think. I am pretty set on getting this kit but if their are things that i do not require that will not affect performance let me know. I want to get this kit, i really like the look of it and feel it will look great in my White Phantek Full ATX case. So thank you for reading my post and commenting. I will check in and read your guys opinions and then make my decision in about 1 week. Thank you and wish you all the best.
7/16" x 5/8"
1/2" x 3/4"
3/8" x 5/8"
