So i'm building my first loop and would like to ensure I'm actually buying the correct fittings for my needs. I am using EK blocks so I thought I may as well stick to EK for my fittings and tubes also.
But first I have a question which may sound stupid but do i actually need a pump top? or are they just for aesthetics?
My plan so far:
12/16mm PETG tube
2 radiators
1 gpu block
1 cpu block
1 reservoir
separate pump under psu shroud
12 HDC 16mm fittings
and then for a drain valve but was unsure how to go about it so I thought:
Pump >>> EK-AF extender 6mm M-M >>> EK-AF T-Splitter 3F >>> EK-AF extender M-M >>> EK-AF ball valve 10mm >>> EK-ACF Fitting 10/13mm >>> 10/13mm softline tube
is this all correct? is there anything you would change?
the more I look at it the less sure I become.
any help would be much appreciated!
My plan so far:
12/16mm PETG tube
2 radiators
1 gpu block
1 cpu block
1 reservoir
