Hello!
I have an i7-6850K paired with dual MSI GTX 1080 TI Gaming X fitted inside the Corsair 780T. I would like to add custom water-cooling and have considered EK's components which seem nice. Do you recommend them? It is my first build and i am not quite sure if i will be able to manage it, i mean connect them to my GPU and CPU so that they work properly. I have gone through their website and it seems quite enjoyable and convenient to choose the appropriate water-cooling components for my specific system, but i am not sure if it will be that easy to actually build it. Do they provide a guide after delivering the components as it is in their website and do you think i can manage it without issues? Also, i already have Corsair GTX 110i cooling the CPU, should i even bother replacing it with a custom one? I would really like to water-cool the GPUs, cuz they are literally burning my legs. Should you have any other recommendations(to change or add components) don't hesitate to write them below.
My system specs:
Intel i7-6850K
Corsair GTX H110i
MSI GTX 1080Ti SLI
Corsair Vengeance 32GB 2400MHZ
MSI Godlike Gaming X99A
Corsair Graphite 780T
Samsung 960 Pro 512GB
Samsung 850 Evo 1TB
Acer Predator XB281HK
Any help would be greatly appreciated.
Thanks in advance!
My system specs:
Intel i7-6850K
Corsair GTX H110i
MSI GTX 1080Ti SLI
Samsung 850 Evo 1TB
Thanks in advance!
