Hey guys,
The last couple of weeks I am thinking about getting a custom water loop for my system.I did some research and I read the sticky on this site about watercooling.I searched for all the components (rad/pump/res/tubes/fitting etc) but I find it easier to get a kit since it comes straight from a single company and all the components are compatible.I really like the XSPC RayStorm Pro Ion AX280 Kit.
This kit gives me a 280mm radiator which fits on the top of my case and has a res/pump combo with 420 lph(1.85 gpm) and a coolant capacity of 84ml.My cpu is an i5 4570k.For now I will use the watercooling for my cpu only but later on after I upgrade my r9 280x,I will propably watercool my gpu aswell.The question I have is that kit gonna be enough or will I need a larger radiator and maybe a stronger pump/larger res?From what I've read the 280mm radiator is gonna be okay but I haven't seen any benchmarks with temps with a 280 rad for both a cpu/gpu.Do you have a similar experience with that kit or a similar one?
PS:This kit costs 255 euros in my country
