Hey guys,
I just recently built a water cooler onto my AMD Radeon 7950 3GB gpu, and I'm trying to figure out if some results I'm seeing are normal. I have an ideal situation, in which my wife's computer is running an AMD 7850 2GB (not identical, but similar) card, so I can *somewhat* compare my measurements. Please note - her card is NOT watercooled (just uses two stock fans).
One of the things I notice is that her card idles lower than mine. My card is always around 32-35 C, but hers never goes above 30 C unless she's running a game or something. That made me think that I had set something up wrong, so I decided to run FurMark on each (using identical settings) and compare the results. After only a few minutes, her card heated all the way up to 80 C, while mine slowly climbed to about 60 C. I ran a few trials and noticed the same results - her card consistently heated up much faster than mine every time.
Thinking this cemented my card's performance, I then noticed something else - when cooling down, her card consistently outperformed mine every single time. Her card could calm all the way down into the 30's C, while mine lagged behind in the 40's every time. Is this just an inherent nature of water cooling? Better performance under pressure, but slower recover time? I pulled my GPU apart and made sure all my connections were on tight, and thermal grease was well applied. What do you guys think?
*Also note - after 45 minutes of running FurMark, I topped my card out at 80 C.
* I am using an Arctic 7970 Hybrid Accelero water cooler.
