Hey all, first post on the forums here, hope you guys can help me out a bit here -
I'm building my first PC in the coming months, and with it being high-end, I was considering water cooling but for the moment the plan is air cooling. I know I could definitely benefit from a water cooled system, as my rig is going to be for gaming/editing. I just had a few issues, so wanted to know if it was worth it or not.
The current price would be ~$5,000 USD with an air cooling setup. Here are the planned specs:
Motherboard: ASUS Rampage IV Formula
CPU: Intel Core i7 3930K
RAM: Corsair Dominator 16GB 2133 MHz RAM
SSDs: 2 Corsair Neutron GTX 120 GB SSDs in RAID 0
HDD 1: Seagate Barracuda 2TB SATA III 6GB/s HDD for Storage
HDD 2:WD Black SATA III 6GB/s 4TB HDD for Recordings (I do screen caps, 1 hour takes ~500 GB of space)
Optical Drive: ASUS B2-12B1ST/BLK/G/AS Blu-Ray Drive
CPU Cooler: Corsair Hydro Series Extreme H100i CPU Cooler
Monitors: BenQ XL2420TX Monitor and 2 ASUS VS248H-P Monitors
GPU: 2 EVGA GTX 680 Classifieds
Sound Card: ASUS Xonar Essence STX
PSU: Corsair HX1050 (80 Plus Gold)
Chassis: Level 10 GT Snow Edition Case
Mouse: Razer DeathAdder 2013
Keyboard: Razer BlackWidow Ultimate Stealth 2013
Headphones: Sennheiser HD598 Headphones
If I added water cooling, it would be using all EK waterblocks. Here are my main concerns about using water vs air cooling:
- I have to downgrade to 2 EVGA GTX 680+ 4GB's so I can use the EK-FC680 GTX+ Acetal and Nickel waterblock, since EVGA stopped making the Hydro Copper water blocks.
- I have to change the chassis to a Corsair Obsidian 800D, so I can fit a top-mounted 360 radiator (and possibly other radiators as well, since the case was designed for water cooling). This isn't too bad, as both cases are fairly equal.
Here's the configuration I'd be using:
Swifttech MCP665 Pump w/Bitspower D5/MCP665 Mod Kit + Top
EK-Res X3 250 Reservoir
XSPC RayStorm CPU Waterblock
2x Black Ice GTX 360 Rads w/ Noctua NF-F12 PWM Fans
Some sort of 6-channel fan controller
XSPC Razor GPU Waterblock/EVGA Hydro Copper Classified Waterblock (if I can find one)
Koolance Radiator Mounting Bracket (to mount a rear 360 Rad)
With this setup I'm looking at around $5,645 for hardware + water cooling. *winces*
As for tubing, I would prefer 1/2" ID Red Tubes. As for fittings, I would prefer Bitspower black fittings, but really, any fitting will do. I also need a T connector and a quick connect for the drain port.
Here is how I envision the loop being, if I decide to pursue water cooling.
Pump --> Inlet GTX 680 #1 --> SLI "Tube?" --> GTX 680#2 Inlet --> 1/2" ID Tubing --> CPU Waterblock --> Radiator --> Reservoir
Yes, I realize that the CPU is not the first thing in the loop but given that the waterblock on the CPU is not the highest flow block around, I thought it best to have it last in the loop.
Anyway, any suggestions on whether I should do water cooling or not, and if I went with watercooling, is the setup I envisioned good?
