custom or closed-loop?For the former, - yes, since by definition custom is just that, custom. For the latter - yes. probably no more than a basic 120mm radiator. That's not really a high-end case with a lot of space and options. and it looks like removing some of those front drive bays will take you into Dremel country - and then you're back in custom.
