This is the first custom water cooling loop I am attempting to build. I have a list of components bellow. Should i change something ? (I know there is 1 fitting only) Also , does the CPU Block need a mounting kit or something? Is there anything else , aside from distilled water and a kill coil , that i may need? Can i opt for a single 120mm fan radiator , or am i lowering the performance?
The site is greek , but the part names are english .
http://www.eworld.com.gr/products/page/1147403952
