Thanks for the recommendation i'll check their custom stuff out!
EDIT: I think i figured somthing out (a bit overkill, okay definitly overkill)
ex-res-432 EK-MultiOption RES X3 250 - Liquid Cooling Reservoir (6 Total Ports) $62.99
ex-blc-1579 EK GeForce 780 GTX Ti VGA Liquid Cooling Block - Acetal (EK-FC780 GTX Ti - Acetal) $125.98
Select an Optional Backplate: EK 780/Titan SE/780 Ti Backplate - Black ($30.99)
$138.98 $416.94
ex-pmp-258 EK DDC X-Top w/ 3.2 PWM DDC Pump (EK-DDC 3.2 PWM X-TOP CSQ - Plexi) $104.99 $104.99
ex-tub-1015 XSPC High Flex PVC Tubing - 3/8" ID (5/8"OD) - UV Green $2.50 $17.50
ex-liq-414 EK Ekoolant EVO Concentrate 100mL - Lime Green $9.99 $19.98
ex-rad-313 EK Ultimate Performance CoolStream 480 XTX Series Liquid Cooling Radiator (EK-CoolStream RAD XTX (480)) $126.99 $126.99
ex-rad-312 EK Ultimate Performance CoolStream 360 XTX Series Liquid Cooling Radiator (EK-CoolStream RAD XTX (360)) $102.99 $308.97
ex-rad-310 EK Ultimate Performance CoolStream 120 XTX Series Liquid Cooling Radiator (EK-CoolStream RAD XTX (120)) $62.99 $62.99
ex-tub-1995 EK G1/4 Thread Perfect Seal Compression Fitting - 10mm ID x 16mm OD (3/8" x 5/8") - Black $6.99 $167.76
ex-tub-3379 EK G 1/4 Logo Plug - Black $4.49 $17.96
ex-blc-1554 EK Supremacy EVO Universal CPU Liquid Cooling Block - Nickel + Green Acrylic (EK-Supremacy EVO GREEN Edition) $84.99 $84.99
ex-tub-1837 XSPC G1/4" 3-Way T Adapter - Chrome $6.99 $6.99
lit-35 Logisys Dual 12" Cold Cathode Kit - Green
Sleeve The Cable(s): Yes (Select Sleeve Color Next) ($8.99)
Select Your Cable Sleeve Color: Kobra High Density UV Green
$18.98 $37.96
Subtotal: $1,500.00 HOLY CRAP!!!!!!!
