Water Cooling Help
lik3abau55
50
Hello all,
I have decided to upgrade my cooling from my H100 to a full liquid loop. I have a Haf XM case and do not have major water cooling abilities. I was thinking of buying the XSPC RayStorm 750 RS240 WaterCooling Kit and adding a 140mm rad at the back of my case so I have a total of 360mm of cooling surface area. Would this kit with the added rad be able to cool my 2700k and GTX 670 (NOTE: The block required for my GPU is a 680 since my card is a non-reference PCB). Can you recommend parts or something of the like?
Thanks very much! 😀
I truth I feel the GPU's today have such good coolers on them already that they really do not need water cooling. Unless you are going for looks more that performance I would skip water cooling the GPU but that just me. I was going to water cool my Sapphire HD 6950>6970 at one point but ultimately skipped it.
As for the RayStorm I have found it to be a very good block. I have upgraded my system with that block and the RX240 rad for my AMD FX-8120 and FX-8350 rigs.
If you go for cooling the GPU as well make completely sure that a 680 block will fit correctly on your 670. You said it is a non-reference PCB do you mean it is a 680 reference PCB?
