I want to custom loop cool my GPU, CPU, and RAM but dont know which parts to pick out for the cooling. I want to keep the price for the loop at $300 or less but want to use compression fittings instead of ghetto zip ties. I want reliable components that will not cause leakage and if I could, please have some help on finding a liquid that will last more than a year but not cause any sort of corrosion to the tubing or blocks. Please help thanks!
~Build~
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
GPU: Asus Radeon R9 270X 4GB DirectCU II Video Card
MOBO: ASRock Z97 OC FORMULA ATX LGA1150 Motherboard
RAM: Kingston HyperX Beast 16GB (2 x 8GB) DDR3-1866 Memory
CASE: Corsair 760T White ATX Full Tower Case
PSU: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
Storage: Intel 520 Series Cherryville 120GB 2.5" Solid State Drive and Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive
Also please comment on what you think of my build and on a scale of 1-10 how good it is, thanks!!
~Build~
