water cooling help
backstabbin
134
hey guys so need help with water colling want to do my cpu and gpu sli but will start off with cpu and save for the gpu later on
so i bought the ek waterblock for cpu 250 res
was thinking of getting this pump https://www.scan.co.uk/products/ekwb-ek-xtop-black-revo-d5-pwm-plexi-high-performance-liquid-cooling-pump-4-pin-molex-and-4-pin-pwm-
im just unsure on what rads to get and tubing i was thinking maybe 2 360 rads when i have the gpu water blocks but for now just 1 360
i just don't have a clue what size tubing to go for there is so many
what do you mean connector? do you mean the fittings? if so i havent ordered any of them yet
Yes it all has to connect tightly personally it would have been easyer to go with a h60 becouse it has every thing you need alredy in there.
allready have a closed loop want a custom just dont know what tubing to go for
Get rubber tubing
yes but there is loads of diff sizes like 10/13
1/4 i dont know what size to get
10/13
