Yesterday I switched my build into a new h500i and switched from air cooling to a water cooled CPU. My benchmarks dropped and I believe it is because my old case was huge and had 10 fans as opposed to this smaller case. I will stress test later but I believe this is not the CPUs fault but actually my 1080 FE thermal throttling too easy. Does anybody know what good 120mm water cooler is for a 1080 and also if that will fit in my case with my front panel being taken up by my cpu rad. If somebody has also done this maybe send a picture so I can see the setup.
Edit: I have seen stuff about editing the fan curve in a 1080 FE, is this a good solution to make the card run better. Right now it his 82C really easily. Also when i mention a performance drop it is only a difference of going from 9150 to 9020 on 3dmark firestrike ultra.
My parts list is:
CPU: 4770k currently No OC
Motherboard: MSI Gaming 7 z97
Cooler: Kraken x52
Graphics Card: GTX 1080 FE
PSU: Cooler Master V850
Case: NZXT H500i
My parts list is:
Cooler: Kraken x52
Case: NZXT H500i
