Water Cooling Kit without backplate
I did a search and I found one without backplate (NorthQ Siberian Tiger II Water Cooler) but I am not sure if it is good for cooling my q6600 3.6GHz also I have room temp 33C. :sweat:
http://www.driverheaven.net/reviews.php?reviewid=694&pageid=1
The problem is that I have a small form factor case and the big air coolers don’t fit inside so the Water Cooling Kit is my only option (because i can place it out side the case) if I want to have my q6600 OC at 3.6GHz.
