water cooling kit X360
don boy
17
I have fitted the water cooling EK kit x360 . mother board asus z270 maximus ix formula, there are 2 connection 1 molex ,1 2 pin , what are the 2 connections for and which header on the motherbaorb is the best for the 2 pin this is the kit i fitted
http://overhard.ru/catalog/sistemy_okhlazhdeniya/vodyanoe_okhlazhdenie_svo/nabory_dlya_sborki_svo/ek_kit_x360/
you have following components in the kit the require power:
1. fans - you obviously can figure it
2. LED
3. Pump - it has 2 connectors. that might be the confusing part (correct me if i'm wrong).
The pump has one 4pin molex connector with only 2 wires and one 4pin connector like on fans - probably with 2 wires.
the big one (molex) connects to PSU and is there to provide the power to the pump.
the smaller (like the fan connector) is connected to the MB - best to the CPU header, but not important. one wire is used for the PWM signal to control the fan speed, and the second is reporting the pump speed so you can monitor it.
All this and more you can find here (a printed version was supposed to be in the box)...
2. LED
All this and more you can find here (a printed version was supposed to be in the box):
https://www.ekwb.com/shop/EK-IM/EK-IM-3831109863268.pdf
