water cooling kits
jay1234567890
39
hi, i was wondering if the Alphacool NexXxoS Cool Answer 240 D5/ST - Complete Kit will work with the msi gaming 7 motherbord, it is intel lga 1150 chip inset, thank you.
Very good choice, you will have enough space for the Alphacool system (the radiator will be mounted onto the top case panel, you will need to get rid of the 200-mm fan though).
Hello,
It's not the motherboard compatibility you should looking for, but if the case can accomodate that big radiator (240-mm length and 30-mm thick without fans) and the reservoir (it needs 2 x 5,25" bays). What case are you using?
The Thermaltake lever 10 gt
