Water-cooling Loop Help
Devouringbowl57
131
Hey guys, I am a real water-cooling nub and I am planning to make a water-cooling build. I have all the parts except the water-cooling things and I need help planning out the loop because as previously stated I know very little about it. I'm using the enthoo pro case and I intend to put a 360mm radiator on top and a 240mm in the front. I want to use an EKWB acetal cpu block and an EK X3 multi option reservoir because have the reason I'm doing this is looks. I need help planning out the loop and I'm going to cool my dual 970's an i5 4690k nothing else. Oh and btw a picture would be super helpful thanks for anybody willing to spend the time to answer this.
Your first stop is the W/c sticky, this will arm you with a lot of required knowledge upfront and assist you in planning out the loop, and we cant post a picture of what your loop will look like, thats up to you when you build it but you can check out the gallery for some inspiration 🙂
Moto
Moto
