Hi everyone,
I installed a CPU water cooling block a few months ago with:
Raijintek Triton 280mm AIO Water Cooling Solution
It has a red dye to it, which is regular red coolant. It's been working perfectly normal the first few months. A few days ago I noticed that the colour had turned from a dark red to a light brown, then almost transparent. As though it was dirty water.
Here's a photo of what it looked liked when the colour faded:
http://i.imgur.com/dDG39X9.jpg
I've added some more red dye to the loop which has resolved the issue. Here's a photo of the added dye:
http://i.imgur.com/qfJV3aE.jpg
However, it's been a few days and it's slowly started to dilute again. I'm uncertain why it's been perfectly fine for several months but only this past week it's suddenly started doing this. The loop is closed so it isn't leaking. It isn't in direct sunlight.
Does anybody know what may be causing this?
Thank you.
Thank you.
