I have looked at the WC sticky 2.0, but it never mentioned if I should cool the CPU or GPU first. I plan on building a new PC and thought about trying out WC.
My build:
-Maximus VI Formula [For the cross-chill heatsink as it supports WC]
-I7-4770K
-16 GB Vengeance Pro ram 1866 Mhz
-Asus GTX 780 OC, GTX Titan or ROG Poseidon [For the Air/WC hybrid cooling option]
-EKWB 480mm Coolstream XT or XTX [not sure which is better]
-Corsair SP120 Quiet edition fans
-EK-Supremacy - Acetal + Nickel
-Solid tubing
-Corsair 800D/900D
My questions:
-What should the order be? currently, its
res---->pump---->rad---->CPU---->cross-chill VRM heatsink---->GPU
-Which rad is better? between the two, as my country only has EKWB
-What type of GPU water block is best? full cover or GPU only?
-What res and pump do I need for a single GPU and CPU loop?
-To do a loop with solid tubes, what thickness must they be? As most guides use standard tubing.
-On EKWB CPU blocks, whats the difference between the acetal, nickel and copper blocks?
-Should I add the chipset or ram to the loop?
-Are there decent alternatives to distilled water? Most of it in my city is actually de-ionised even the batch from the school's labs.
I may have more questions as I come to understand more about WC, and before you refer me back to the WC sticky, I HAVE READ IT BUT THERE ARE STILL QUESTIONS WHICH I PREFER A DIRECT ANSWER FOR. Caps just to emphasize my point.
To those who respond, thanks for any assistance rendered. Thanks for the help.
My build:
-I7-4770K
-Solid tubing
-Corsair 800D/900D
My questions:
