Hello, I'm building a ridiculously expensive complete overkill computer with two seperate loops and I am a little unsure about how to implement two pumps in a single loop.
I have the CPU loop all sorted but I'm stuck on the GPU loop, currently it would look like this;
Res > Pump > Res > Pump > Rad > Rad > GPU > GPU >>>
So my questions are:
1. Would this be an issue.. a pump feeding directly to another pump?
2. Or on another note, would having a pump feed directly in to a res be completely pointless. Or...
3. Would this work fine due to having a pump on either side of the loop one pushing the fluid through the rads then the blocks and then another on the other end sucking the fluid out? I'm very conflicted on how exactly it would work.
I would obviously much prefer to have it look more like this;
Res > Pump > Rad > Res > Pump > Rad > GPU > GPU >>>
But doing so using the middle and right side rads on a Thermaltake Core P7 would be pretty complicated to implement and would look rather messy.
Thanks in advanced to anyone willing to give their opinion or suggestions.
