Water cooling my pc with...
VXsz
40
i want to water cool my pc using radiator(with fan) & cpu block only
my qustion: is it possible to do it withot other things
With that many fans and the case being open. Even with a stock heatsink it should not be getting that hot unless it is being overclocked. The Cryorig H5 Universal is a good choice for under $50.
http://pcpartpicker.com/product/jK8H99/cryorig-cpu-cooler-h5universal
i'm gooing to buy tubes of course and for the aio coolers i just want to make simple and cheap water cooling loop they're very expansive for me only H60 might i can afford
btw sorry for bad english
The prepackaged closed loop units are usually cheaper than all the parts you need to build your own system.
Are you doing water cooling because it looks cool? Air cooling is often cheaper and quieter. A good air unit will outperform most liquid cooling solutions. Some of the larger 240mm to 360mm units may do slightly better under load and overclocked. But not much better.
From a practical perspective. Air cooling is a better option. Those 120mm water coolers get beat by $30 air units.
A good mid range air cooler would be the Cryorig H5 Universal. A high end option like the Noctua D15 performs exceptionally well.
ok but i just want my cpu to be cool because its getting temps like 100c on about %40 usage
btw i want a good air cooler under $50 for the price if you can i have i5 3470
What case do you have? Make/Model
How many case fans are installed and at what locations? Front/Top/Bottom/Rear/Side
Gigabyte Luxo M10 but the right side on case cover isnt there so i think any sizw will fit and my case has 4 fans
