I have been on a planning spree today for my upcoming (first) PC build, and due to the capability of my case to have water-cooling, plus having two crossfired Sapphire Radeon 7990 HDs, I have decided to go with water-cooling. I have done my research, and so far, I have chose some top-reviewed parts and tried going through the path. These are my parts so far-
Case: Aerocool XPredator Devil Red
Reservoir: Monsoon Series Two D5
Pump: Swiftech MCP665-B
Top Rad: Black Ice GT Stealth 280
Bottom/Rear Rad: Black Ice GT Extreme 140
GPUs: Sapphire Radeon 7990 HD Crossfire, each is a dual-GPU
GPU Waterblocks: 2x Swiftech Komodo HD7990 Full Cover
(No connectors yet, not going to research some until I am certain of path)
I have generated two paths, and I'm not sure as to which is the better choice, and which will have the greater benefit towards the cooling of each component. The case is capable of holding 1 140mm fan in the rear, 1 140mm fan on the bottom, and a 2 x 140 Rad on the top. Being that I want to have the GPUs cool, I want to ensure that there are radiators in each spot. Hopefully this doesn't restrict airflow in the case though. The four fans in the side panel should take care of this problem.
First Path:
[/URL][/img]
Second Path:
[/URL][/img]
If there is a third path that would make this better, please let me know. Any help will be appreciated. So far, I have had no problems with the fast responses on this site.
P.S. I have no idea what the HTML text beneath the pictures is doing there, I know HTML and know that I didn't type that at all :\
First Path:
Second Path:
