Ralston18 Titan Moderator Oct 11, 2014 34,905 3,324 146,290 Oct 3, 2018 #2 More details needed: What is your build? Components, case, PSU, etc.. Overall the answer is to place the pump per the manufacturer's installation guidelines. If that is a problem for some reason then you must explain the details. Upvote 0 Downvote
Lucky_SLS Glorious Dec 16, 2016 7,914 828 44,340 Oct 4, 2018 #3 Also tell which pump you are using, which radiotor you are using and clearance you have. Sharing a photo would be much better. Upvote 1 Downvote
