Water Cooling Pump - Is this suitable?
It seems okay, not exactly a brand pump but it should do the trick, From what i can see it connects to your motherboard via a fan header, so make sure you have a 3-pin fanheader free on your motherboard, otherwise you need a splitter or adapter aswell.
When it comes to performance or silence there really isnt enough information, and personally i would go with a pump that have a better reputation. (that being any reputation at all)
Okay, could you recommend anything too me that would be a more reputable brand pump instead? I would pay upto £75 for one. Thanks.
no problem!
glad to be of help.
