water cooling question
Jacob Bowerman
251
hello, im new to building computers, however i feel confident in them. when it comes to liquid cooling systems. is it a given that it will fit in all sockets? or does it have to be given in the specifications of which socket it fits? is this a good one? assuming the case is big enough for it. are there any other specifications or problems i should look for? this is more of my dream pc (I've only just started saving so i got a lot of time left)
here is the cooler:
http://www.pccasegear.com/index.php?main_page=product_info&products_id=23457
here is the cpu: (intel core i7 4930k)
http://www.pccasegear.com/index.php?main_page=product_info&products_id=24964
here is my build if your interested:
https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=254807&action=wish_lists
Yes it will fit. I noticed you're going to use dual 290x's; a good choice, but for betting gaming performance I'd suggest going for 2 GTX 780Ti's. There's a Galaxy one on that site for the same price, MSY is selling a Gigabyte one for $20 less.
i originally went with GTX 780Ti's HOWEVER i intend on doing a bit of bit coin mining which is why i went with ATI's, simply because they are considerably better at bit coin mining then nvidia cards
