Water cooling question
BuildNoob
19
Will copper and brass in the same loop cause corrosion. I know the whole dont mix metals concept, but this seems like a unavoidable and possible issue.
Copper and brass are perfectly fine - most radiators are a mixture of copper and brass. Most fittings are brass that is typically plated.
You really want to avoid aluminum. Copper, brass, silver, nickel, gold are all pretty safe when used together but corrosion can take place after a long period of time (in terms of years). Since a watercooling loop likely will be (and should be) disassembled around once a year for cleaning and maintenance, you should be able to easily inspect everything just to keep an eye on it.
Copper and brass should be fine. Here's a good link about galvanic corrosion. If it's something you're worried about, just run a coolant with a corrosion inhibitor.
https://martinsliquidlab.wordpress.com/2012/01/24/corrosion-explored/comment-page-1/
