I bought a computer a few years ago with water cooling. It cools the CPU only. Its a simple system where the CPU waterblock and pump are one, and then there is a radiator with a fan. There is no reservoir. I've been using a program to monitor the CPU temp. Not sure if it's a good one, because it doesn't show all the fan speeds. When the system was new it would show an idle temp of 25~30 degrees Celsius. Now it idles around 40 degrees Celsius. Under load I have seen it at 51 degrees Celsius. My CPU is a Intel Core2 Duo E6750 @ 2.66GHz. My questions are as follows:
What program/how would you recommend monitoring temps?
Would adding a reservoir/ more liquid to the system provide better cooling?
Is there maintenance I can do to check if the cooling system is running optimally?
How hot is too hot?
How hot is too hot?
