So I am trying to build a custom water cooling loop and I wanted to ask if for my pc which has a 6700k and a gtx 1080 msi aero 8gb oc how many rads do I need if I want to be able to overclock both I am think about getting a 360mm rad for the top of my case which is a corsair 760t and then a 240mm rad for the front of my case so my main question is, is that overkill for what I am cooling and second question is how should I route the tubing like loop order whats that best way to do it. Also a third question how much tubing would need for my loop, I currently have about 78 inchs but I'm not sure if that will be enough.
