Hello,
I installed a kraken g10 on a 290x. I used a corsair h90 for the pump, I also used enzotechs 9mm copper heatsinks to cover all the memory. I also used gelid heatsinks that are fitted for the vrms on the card. I also put in a different fan that had better output. When I installed everything, I was able to boot to windows to check idle temps.
Vrm 1: 27c
Vrm 2: 30c
GPU: 34c
So I turned on Tomb Raider, got into campaign. Checked max temps
Vrm 1: 50c
Vrm 2: 54c
GPU: 53c
About 30 seconds later screen would go black pc still on, no beeps blue screen or anything. I Reset the computer nothing, unplugged it plugged it back in. Got to windows, same idle temps. Started up Tomb Raider again, same max temps, 30 seconds later black screen. I made sure pump is working, fan is on. Good contact with heatsink to gpu. Radiator fans on 100%. I made sure the screws were in the hole slot for 290x on kraken back plate. Also made sure not to over tighten and bend the card. Any ideas?
Vrm 1: 27c
Vrm 2: 30c
GPU: 34c
Vrm 1: 50c
Vrm 2: 54c
GPU: 53c
