• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Water cooling setup to O/C new build
narcotix
4
Hello Everyone :) I've been reading these forums for a while now and i got interested in a non air cooled solution. You all seem very knowledgable regd cooling so thought id ask for your advise on this..... I am thinking of getting the following parts
Danger Den D5 12V Water Pump $99.99
ThermoChill PA120.3 Triple 120mm Radiator $169.99
Swiftech Apogee Extreme Duty Universal CPU Water Block $44.99
Thermaltake USA Inc
T-type Water Temperature Indicator $39.99
Thermaltake USA Inc Flow TX Flow Meter for Liquid Cooling System $24.99
PrimoChill PrimoFlex 1/2" ID x 3/4" OD UV Green Tubing 10-Foot Coil $24.99
Danger Den MCT-40 Non-Conductive Cooling Liquid 32 oz $24.99
SUBTOTAL $429.93 - all from microcenter cus i can return stuff easily :D
Radiator choice was based on reviews like this...
http://www.xtremesystems.org/forums/showthread.php?t=77260&highlight=challenge
I wanted to know if you think this might be better than getting a system like a zalman reserator xt from newegg at http://www.newegg.com/Product/Product.aspx?Item=N82E16835118032
for $419
Or are there other parts that you would reccomend?
Thank you much!
oh.. this is the system i am going to build and O/C: :bounce:
Western Digital Raptor WD740ADFD 74GB 10000 RPM SATA 1.5Gb/s Hard Drive
HP w2408h Black 24" 5ms HDMI Widescreen LCD Monitor w/ Height & Pivot Adjustments
EVGA 768-P2-N882-AR GeForce 8800Ultra 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card
ABS Tagan BZ Series BZ1300 1300W ATX12V / EPS12V Patent Piperock Modular Power Supply
Crucial Ballistix Tracer 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model BL2KIT25664AR804
ASUS Striker II Extreme LGA 775 NVIDIA nForce 790i Ultra SLI DDR3 ATX Intel Motherboard
Intel Core 2 Extreme QX9650 Yorkfield 3.0GHz LGA 775 130W Quad-Core Processor Model BX80569QX9650
Midway OEM PC Game, Intel Gift
mobo, gfx subject to change....
phreejak
1,376
Well, some of the parts you listed I would change (for various reasons) but that is somehting to get into later. Right now it would be helpful if you could make a few things clearer like o'clocking.
Will you be aggressively o'clocking or just mildly?
What components do you plan to o'clock for that matter?
In your o'clocking, do you plan on altering your voltages?
Do you intend on staying with a single rad solution or do you have any opinions to a dual rad cooling loop? (Of course, this will also be affected by your o'clocking intentions)
WestWarrior
105
For performance in your loop, I would take out the Thermometer, the flow meter and the coolant. Replaced 1Gallon Distilleld Water and additives.
A few questions arise though.
Your radiator choice really depends on how far you want to OC this thing.
Make sure you have either a T-Line+Fillport or a Res.
Tygon 7/16" tubing is something you should consider as an alternative to Primochill.
narcotix
4
Ah, thanks for replying!
well i am first going to try out the cooling on my old system that i want to aggressively o/c. If that works out well i will do the same to the new system.
The old system:
My main problem with it is that my 6800gt gets hot very quickly...
graphics card:core 351MHz, mem 1002Mhz, volt reg temp 57C, core 65C idle...102C load
cpu: athlon 64 3400+ 2.2GHz @ 2.42 mobo at 30C cpu at 40 C idle, 46 C under 100%load, 1.55V
htt 220Mhz multiplier 11. I got it up to 2.6 but it was running very hot because i had to raise the voltage.
cpu fan: i have a zalman cnps9700 led at full speed...
In both the old and the new i would like to cool cpu, graphics and northbridge.
My old one, i have fewer options to o/c the cpu but i want to concentrate on the graphics there.
I will be gettin a reservoir because i have read that t-lines take ages to get ready? do you agree?
And ya the tygon is a better tubing..:) but why 7/16"? so that it is a tighter fit?
The new setup, i would like to aggresively o/c.
Thanks again!
WestWarrior
105
Yes 7/16" gives you a tighter seal. You will probably want to go with a triple 120mm rad for either setup.
A word from the wise though. Never watercool your only PC(s).
phreejak
1,376
Two words: cable management.
Try and get your cabling under control (and hidden) for better airflow for those parts that aren't watercooled.
Second, by aggrssively o'clocking I mean the ram, cpu, gpu and altering the voltages. If you plan on doing that with either rig than a NB waterblock wouldn't be a bad idea. Otherwise, a decent HSF combo and some good cabling would do just fine.
narcotix
4
phreejak and westwarrior
... will do as you say regd the 3*120 fans and the nb water block.:)
BTW, I tried out a thermaltake duorb G0102 vga cooler and it dropped my temps by 24C idle and by 50C under 100% load but i still wasnt able to raise my core and memory clock speeds by much (aquamark, 3dmark freeze midway through...) does that mean i should raise the voltage?
closed_deal:
lol the compass is cus im directionally challenged :) .. i just didnt have anywhere else to put it.... nice
Similar threads
