I'm looking for a water-cooling system for my Intel I7-3770K which I want to start overclocking.
This is my motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821
This is my case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133191
(Will the parts fit?)
2nd, what do I get for another 240mm fan to screw on the side of the case?
Lastly, When I'm screwing in the radiator on the case, what size fans do I need to put on the radiator. Also, do I position the radiator on top of the fans, or do I place the fans on first, then the radiator below them (when screwing into the top of the case).
