Have just started to check a problem due to noise or leak in the water cooling kit for a friend.
The problem is I can hear air/water leak from the reservoir tank. This is the screw in button that is on the top.
So far the screw top was already a little loose. when applying pressure to the pipes the air/water seems to escape so now afraid to turn on the system again because it has become so loose. Then decided its time ask here.
what I would like to know is could this be a common problem. That just buying a new one will fix.
If not then its a new reservoir tank.
Just hope so then i might as well get some new tubes and maybe renew some of those that seem to have gone alittle softer than we would expect
