Water Cooling Worth It?
jinshifu
47
Since almost everyone here has watercooled pcs, I was wondering if it was worth it. Is there just a few degree drop in temperature when water cooling is used? Or a huge one? I can see that with a water chiller the difference is huge, but it sounds troublesome and risky with condensation problems...
If he will DIY it can be done for around $100.00 but I dont know if the first time should be a DIY.
<font color=green>NED FLANDERS FOR PRESIDENT</font color=green> Its justa nother gansta PARTY!
Intel P4 Extreme(3.73)@<font color=green>5.6Ghz</font color=green>
Asus P5AD2-E-Premium
Crucial Ballistix DDR2 667@DDR2 855
I know you were. Go answer my question in the motherboard section.
Yes I think its worth it, I still use the aquarius 11.'Out of the box hooked up' I was getting temps around 34 to 42 core temps. I was in the mid 50 to 60 even higher if I overclocked while using a stock heatsink. On the other hand a good heatpipe may do almost as good with less hassals but I don't think so unless you have a real good custom made case that has the best air flow and space.
I have never had a condensation problem when using watercooled system,not untill I chilled the water did the condensation start.
I have used this water cooling setup almost 3 years and it has been a real treat being able to overclock ever machine because the system is cooler.A cooler processor all the parts work better, frame rates increase, system runs smoother and faster refresh rates in higher resoulations.
didn't he say that he used those specs for three years? lol, again, you got served =P.... dammit, i can't wait until i actually buy my new comp.... stupid intel and locked willamette -_-
<font color=red>gforce mx100/200 @ 230/440 =]</font color=red>
The chip date on my process says 2002 and it was bought I think in aug of that year so I am a few months short but I still have been using this water cooling for over 3 years and my other processor the 1700 ax1700dmt3c was at 2 volts I
'v even had the xp at 2.2
For my setup I'm getting:
CPU
Idle = 33c
Load = 37c
Case
Idle = 30c
Load = 35c
Ambient
x = 25c
x = 27.8c
Athlon 3200+ Winchester
Thermalright XP-120
1GB PC3200 Corsair
ATI x800XT + Silencer 4
Antec Neo Power 480W
Antec SOHO file server case
4 Panaflo 80mm case fans
Acousti Pak Deluxe + Dynamat
I personally feel that with this setup watercooling definatly isn't worth it for the cost, hassle and risk. My system is whisper quiet often times I've had to look at the LED's on my case just to make sure it's still on and downloading files etc when I have the monitor off. Runs almost as cool if not cooler then most moderatly priced water cooled setups. I've even had the CPU overclocked to 2.8Ghz and the temp only went up to 40c
Only reason you should want to do watercooling imho is if you intend to do some serious overclocking of both the CPU and video card and water cool both. Or, if you're just really into modding and have the money.
<P ID="edit"><FONT SIZE=-1><EM>Edited by zarlaan on 06/21/05 03:15 AM.</EM></FONT></P>
ya dude, with those specs, you don't need to Watercool.
the only real reason for watercooling is if you're using a Prescott. those things are BEASTS!
i was runnin mine with boxed cooler >55c on idle. woudl hit 65 easily when loaded. I decided to get a watercooling kit.
my scotty now runs <40 idle and aronud 45c load.
just my vid card now hitting around 80c when on load
it's called not KNOWING WHAT THE FUXX I'm doing 😛
first forray into watercooling. and for what it does. i'm impressed. easy to instal. simple design. and it works and very reliable too.
as I stated. My Scotty on boxed cooler was running around 55c when idle and was near 70's on load. with the kit i did get on load it gets to about 45c. and stays idle < 40. I'm sure if i built everything myself i COULD do better.. but since i'm not an overclocker. works good for me
g5 has so much bling factor
<A HREF="http://home.comcast.net/~kjboughton/DSC00641.JPG" target="_new">http://home.comcast.net/~kjboughton/DSC00641.JPG</A>
I poured my on waterblock and its ugly has shite but ive hit 5.6Ghz so if it gets the job done then I say BLING BLING to my ugly arse waterblock.
I used the shape of a Thermaltake Bigwater Waterblock but changed the flow channels and made it much thicker. I have a pile of copper pipe so I melted some down and poured it myself. I bet you wouldnt guess in a million years what I used for the mold.
