Question Water cooling
Mar 15, 2019
Need some help. Anyone know if a 120m aio would fit in a 120mm fan mount? Case aerocool cylon mini.
Maybe yes, maybe no. Normally there's no restriction on radiator mounting, but being as the only place is in front, the reservoirs over/under the rad might interfere with case chassis, hdd bays etc. Mounting will be a challenge for sure, make several dry runs before bolting it all down. I'd suggest you use 2x fans at intake and get the best quiet 80/90mm (I'd go 92mm and figure out my own holes) you can get for exhaust.
Reactions: Zefo_
Thanks for the information
