water cooling
khrisjon1205
37
have a xp 2400 and wanted 2 take it that little bit further using watercooling does any1 no where i can get this from cheaply will want to use it 2 cool graphics card in the future
thanks
peace
Better of making one yourself. Kits suck.
Mobile Barton 2500+ @ 2420mhz 11x220 1.7v
Asus A7N8X Dlx 440 FSB
1gb Geil GD pc3500 Dual Channel (2-3-3-6)
Segata 80gb SATA 8.5ms seek
ATI Radeon 9800 Pro(420/720)
Y does everyone think kits suck? I know where to buy watercooling kits and parts, but I live in england so I dont know if it will be very usefull to you.
[Insert witty comment here]
I would highly recommend going over to www.xtremesystems.org and visit their liquid cooling forum.
There are people there from all over the world so finding companies that are locate in England should not be a problem.
They also have lots of people ' in the know'
Hope this helps.
I just bought an waterchill cooling kit from asetek for £217, thats the most expensive version though. Have a look at:
<A HREF="http://www.overclockers.co.uk/acatalog/Water_Cooling.html[/url
www.waterchill.com" target="_new">h... cost you £200+. [Insert witty comment here]
will all this kit fit in a standard ATX case:
WaterChill CPU/VGA/Chipset cooling kit - KT12-L20 (220V)
The KT12-L20 is the flagship and ultimate package for PC end users looking for a complete water cooling kit. In this kit the end-user will find everything that one could wish for to cool down any PC, incl. CPU, VGA and Chipset. Besides the increased performance, an extreme low noise level will be achieved!
The KT12-L20 represents the most outstanding water cooling solution available on the market
today. High performance, low noise and 100 % stability characterizes this kit. Installing this kit
in a PC will make it a dream machine - no more no less!
KT12-L20 component overview:
WaterChill CPU cooler block supporting
Intel P4 S478, AMD Socket A,
AMD S754/S940 (AMD 64)
WaterChill VGA cooler block supporting Nvidia/Gforce ad ATI/Radeon AGP cards
Note: VGA block is delivered with elbow fiitings [Not shown at photo]
WaterChill Chip set cooler block supporting Intel, AMD, SIS and VIA chip sets
Black Ice Pro Radiator with push on fittings
120 mm Low Noise Sunon Fan
700 l/hr Hydor Pump with push on fittings
WaterChill Plexiglas Reservoir
WaterChill Tube Set (3,0 mtr.)
ALL fittings and mounting accessories are included
Anti Algae Fluid - 25 ml bottle
Heat Conduction Compound - 2 ml tube
Installation Manual
Manufacturer Suggested Retail Price ex. VAT [Within the EU ] € 245.00
peace
I will fit, if you search on google for waterchill you can see examples of people that have put the kits in standard ATX cases. However it will be a bit of a struggle trying to fit everything in. Im using the KT12-L30 kit and did have a it of trouble fitting it into my full tower case, but that was mainly due to my dual radiator.
