Question Water cooling
As long as they are both 5V, yes. Physical connectors and the like may differ between various OEMs, but the ARGB 5V and 12V RGB standards are often found on motherboards as well.
Thanks for the reply...as I don't have headers on the motherboard and was wondering if it would do with a controller
Yes, a standard 5V ARGB controller should be able to control any 5V ARGB compatible device. You will then have to use the software that comes with the controller for everything. They usually plug into a USB 2 header on the motherboard, so you need one of those free.
Reactions: MrAnderson90
