Ok So I am planning on buying a H240x or the new Fractal-Design s36 to start My water loop, I have two 970's running SLI. The one on the bottom runs about 10 degrees hotter than the one on top. (obviously the bottom one receives the hot air from the one on top) My question is, Can I buy one GPU block this month and add it to the GPU that is hotter and then later on complete My loop? Can I do that or do I have to buy both GPU blocks at the same time? Also, Do I have to buy those SLI water blocks things or can I use a normal SLI bridge?
P.S. Sorry about My Grammar/punctuation
