Hey folks.
Dropped a little tap water (not more than 50ml) on the top and one side of my pc case. Pc was turned off and the water hit the top of the cooler of CPU, motherboard and, by the side, perhaps a little inside the GPU. By sight I could only notice a drop on the motherboard atop one pin. It was turned off but as I first moved the case, before disconnecting cables, I swear I saw a light go on, the fans started but then shut down, even though I didnt hit the button.
Flipped the case, water came out, then I had a major fan on for 22 hours and tonight tried to turn it on. It turned on, all fans working but the monitor displayed the message "NO DVI SIGNAL". Even after plugging cables again this still kept going.
Did I fry GPU or MoBo? Should I wait more days to see if it comes back or just replace asap before more damage is done?
Thanks
Thanks
