• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Water or Air cooler for i7-6700K ?
knowledge2121
425
I want to overclock an i7-6700K. I am considering to buy the Noctua NH-D15, Will water coolers perform better than the D15 ? if so, which ones do you recommend ?
Phaaze88
Illustrious
Ambassador
1)6700K, even with an overclock, is still below the point where liquid coolers overtake air.
2)Nothing wrong with the NH-D15, though I prefer, and currently use the D15S: performs on par with the original, with none of it's compatibility issues... it doesn't have a Chromax version, which is the only downside.
AngelJin
Proper
Jun 19, 2020
179
48
120
4
Before u buy anything u can oc ur cpu with cooler u have now and see how much voltage u need minimum to boot maybe u won the silicon lottery maybe u lost it so the oc plan u have on ur mind dont work as u intend too at first no reason to run stress test to if the oc is stable just look if the system boots and at idle temps. I own D-15 chromax black i5 8600k is my cpu and performs real well and i dont like water cooling cause in case of fail u might need to replace more than a cooler. I ll attack u 2 screenshots to see some temps cpu run at 4.1 and cpu run at 4.3.
