Water pump broken?
Joey109
Commendable
Mar 3, 2016
11
I kept getting error code 9C and I couldn't get past the load screen on startup. Not even bios. Today I took everything apart again and booted my of leaving the usb connector off of the pump block since I was told it wasn't necessary. I started it up and everything was well. I ran an AIDA 64 stress test and my temps jumped up again, ~85 degrees. I turned off my pc and changed where I had my rad fans plugged and then started up again. Still high temps. I tried plugging the usb connector into the pump and again I got 9C. Once I unplugged it I start up and it says my overclocked failed and sends to to bios. Once I leave there I'm able to log back into my computer but still have really high temps. When I turn my computer on I can hear the little slurp? sound of the water pump. I have a sufficient amount of thermal paste on the cpu (I use gc extreme). I'm just at a loss right now and have no idea what to do since it's literally just the cpu temps causing problems. I don't think anything is old since it was all bought in Sept. '15.
Asus Maximus hero viii
I7 6700k
Corsair h100i gtx
Corsair hx850i
NZXT 410
Corsair vengeance 16G DDR4
EVGA gtx 970 ftw+
do you have the stock cpu cooler still? maybe throw that on, and try? I had a pump fail on my H60 few years ago, corsair will RMA for you most likely, I know my H100 idles at 13 degrees...so yeah something major goin on..
